vagabond
In trying to get to the bottom of a chronically overheating engine at mid to high RPM, I removed my valve cover last night to find that the oil is not spraying out as liberally as I'd like it to, which points to either a faulty oil pump (not likely) or an oil passage blockage. At the moment I'm leaning towards a blockage. The sump oil filter is new, the small oil filter is clean, timing/valves/points are all correctly adjusted.
I'm planning to run some more seafoam through the oil tonight, idle for 10-15 minutes or so to work it through, then change the 20/50 to 10/40 for now to see if this makes any difference.
Does anyone have any advice on how to diagnose an oil passage blockage and where to start to address it? Since I don't have the nerve to do a tear-down with my limited maintenance experience, I'm becoming resigned to possibly having to take it in to a shop. But for now, I'll do everything I can short of a tear-down.
Thanks in advance. This forum is terrific.
