erice1984
So I am confused with this whole sump strainer filter.
Why does anyone use it if you can use the setup Mike's XS oil heat sink/Heiden Oil Filter/Cooler Kit/Honda filter setup?
If the Honda uses pressure side filtering and uses that filter its good enough for the 650, right?
If that is the case why not just remove the sump strainer filter and not worry about it?
I just want to know, leaves more room for oil.
Thanks
-Eric
Thanks
-Eric
