ffgrose
ffgrose
First some back story. I purchased a 75 XS650 that was turned into a bobber. It came with a box of parts, another rolling frame and another engine (1981). The PO was selling because he "couldnt get it running right". Upon inspection, someone had smeared RTV around the the cylinder base to stop an oil leak. This did not work. To figure out the "running right" issue, I (and a friend) pulled the carbs to find no main jet in one of the carbs. After a cleaning and installing the correct parts in the carbs, the bike was running much better (still needs bigger mains and pilots). After putting some miles on the bike, the oil leaks were bad enough to cover pretty much everything behind the motor in a nice coating of oil. A lot more then what I would consider as "normal". After some research, the time to pull the motor, replace the gaskets and reinstall seemed a little out of my abilities (I know its not terrible, but i have another motor so what the heck). I recently pulled the 75 engine out to replace with the 81 engine that appears to have new seals in all the right places (cylinder base and head). Correct me if I'm wrong, but I can move the Pamco Electronic Ignition with E-Advancer that was in the 75 to the 81. I realize the 81 has a TDI ignition setup, but I know the Pamco works. Long way to get to the question, but what spacers and bushings do I need to install the advance rod in the 81. I found some parts on MikesXS, but I'm not certain. Here are the parts offered.. Camshaft internal bushing for advance rod, camshaft internal bushing labyrinth seal and camshaft internal cam needle bearing. Also, does any of this require pulling the top end apart. If so, I may reconsider going with the engine that I'm positive runs. Sorry for the long story, just want to provide all the facts.
