pamcopete
Ride.Enjoy.Life is Simple
Here are a few note about binding.
First, the spanner nut must be installed with the lip on the outside. Having the lip on the inside can distort the position of the advance plate and cause the locating pin to be pushed in and contact the inner brass bushing.
The retaining pin for the advance mechanism locating pin protrudes on some units as well and should be filed down;
Also, the locating pin for the advance mechanism may be too long which causes the pin to press on the inner brass bushing distorting it enough to cause binding. This can be felt when you install the advance plate if it is hung up on the locating pin, then file the pin down. The locating pin should just keep the plate from rotating. It should not cause it to bind.
In any event, I recommend that you use two brass bushings on the right side and just one brass bushing on the left PAMCO side. Do not install the labyrinths.
This recommendation is mainly for converting '80 to '83 models over to the mechanical advance. You can leave the earlier models as is.
