ZeroDistortionNow
- Messages
- 14
- Reaction score
- 0
- Points
- 1
Ok, so with the PAMCO ignition, I am going to use a key switch and a toggle switch. My plan is to turn the key switch on and then flip a hidden toggle switch before the "Scrappy" can be started..
I have a 2 position toggle switch that has 6 spade terminals on the back.
This will allow me to supply power from the battery to the key switch.. through my fuse.. then through the toggle.. and on to my power supply wire on the pamco.
Then, when I want to turn the ignition off, the toggle allows me to not only cut the 12+ VDC from the battery but also grounds the circuit via one of the other spades on the toggle.
My question is this...
Will this be an acceptable means of "killing" it? WIll it damage the pamco when power is cut off and then grounded? Will the micro second of time between toggled from + to - be enough?
Or should the toggle just be able to remove the power supply?
thanks in advance..
ZeroD
thanks in advance..
ZeroD
