minnesota mike
Hey everyone. Got an issue to run by y'all.
I'm working my way up to the PMA swap on my '81 650 Special (got stranded last week because the alternator isn't charging adequately - finally biting the bullet). I just got done installing the Pamco ignition, got it wired, started it up (with the electric start), adjusted the timing, everything going just fine.
Then I went and put on the chrome covers, went to start it again, and... nothing. Starter won't turn over. Tried kickstarting... can't get it running. Battery is charged, everything is basically stock on the bike. I checked the connection from the positive terminal on the coil to the kill switch (red/white wire) and it is fine. Kill switch itself is still operational.
EDIT: Finally noticed the ignition fuse is blown. So what could be causing this? I've read over some similar forums but no clear conclusions were drawn, seems to me. I'll check the coil and Pamco tomorrow, per Pete's guidelines.
I appreciate any help.
