Dam dogbunny your killing me. And your right, but I still have to try, just cant let it go.not yet. I'll waste another weekend doing the swap.if I don't get any results then its pamco time or harness or key switch.
The symptoms, runs perfect then stumbles then good again, mostly when its hot.
what I've done, when it stumbls it floods, went thru carbs many times. Using a spare set re jetted with brass floats and works great, tci re soldered, replaced reg/rec, old one was bad , vom everything was good, new high output coil, new fuse block, new led tail light, new petcock, new headlight,
there it is I'm doing it again. Dam it.
Austin is cool, former Dallas resident
