On a stock piston, the numbers stamped into the top of the piston is the piston size. When they make pistons they don't all come out the exact same size. They measure them and match them by size. The sizes are all 74.xxx mm. The xxx part of the number is stamped in the piston. If you only find two didit then clean some more it's there.
With a matched set of pistons they bore the cylinders to match the pistons. All bors are 75.xxx The xxx is printed on the cylinder sleeves below the jugs.
Say the piston says 955 that's 74.958. The sleeves sat 010. That's 75.010. I have set wqith those numbers. Now subtract the piston from the sleeve and you come up with the piston to cylinder clearance when it was assembled. In this case, 75.010-74.958= .052, that's right in the middle of the .050-.055 spec.On oversize pistons the are marked with the oversize in mm the first over size is 25 as in 75.25 mm, second is 50, as in 75.50. Your 1.00 is 76 mm or fourth over. The 3 might be some other companies third over.
I would measure them. Pistons and bores.
The stock sleeves can be bored out to 12th over. That's a 78 mm bore. This makes the 650 cc engine a 707 cc engine.
If you don't have tools to measure, most any machine shop does and will measure your parts for a small fee.
Once you find out what you have, then you can decide what to do.
Hoo's Racing has those 707 cc pistons.
