BigColdWetNose
Drive Fast, Take Chances
I see the threads with the PAMCO's and OEM electronic ignition run a single coil. I can assume that both cylinders fire together. The points system completes the circuit alternating left & right cylinder ignition.
Has anybody used a Harley single coil and jumpered the points together? I have just picked one up that is wired that way. Don't know what kind of problems I might run into or if this will be OK until I go electronic.
