That sounds fine.
Let me put it another way.
The early (non indexed) hub and pressure plate must be kept together as a set.
The later (indexed) hub and pressure plate must be kept together as a set.
The early clutchpack must be kept together as a set.
(6) 3.5mm frictions + (5) 1.6mm steels.
(You can toss the (6) spreader o-rings)
The later clutchpack must be kept together as a set.
(7) 3.0mm frictions + (6) 1.4mm steels.
All other parts are interchangeable, but:
Best to use the matching retaining nut/washer for the hub.
Clutch springs may have a history, replaced with upgrades and/or aftermarket. For these I'd recommend selecting a matched set of (6), by wire thickness, winding counts, lengths. Or install new ones.
Edit: Check the primary gear lash if swapping the clutch basket. You may want to use its matching crank gear...
