hi folks, I just re-cleaned my '80's BS 34 carbs again after they'd gotten gummed up months ago. Replaced the float needles and the part they sit in, rubber caps over (under?) pilot jets and also float bowl gaskets.
Put them back on today, and the bike doesn't want to start easily.
Finally got it to run just now and it feels as though it's running only on one cyl. Very slow idle, even with choke pulled out. I also replaced the mixture screws and set them identically before putting the carbs back on.
For now I have those "clear" plug caps so you can see when it's firing. Even when running at that very slow, no-good rate, both sides are firing ( i see spark at the cap). Could it be a dead cylinder even if the plugs are firing on both sides (at least at the caps)? (is that possible)
It tried at one point to go ahead and run on both sides, I think, but I went ahead and shut it down thinking it just wouldn't be good for it to run that rough way and wanted to avoid a backfire situation, as the neighbors have a baby, etc.
Was just reading the carb guide and it says if you replace the float bowl gaskets that you must punch out all the little circles in the gasket, or the enrichener circuit won't work.
Question: when it's running with choke pulled out, is that simply adding additional fuel? or does it also block out the regular fuel flow and run JUST on the enrichener circuit, until you push the lever back in?
I'm almost thinking it's just not getting "enrichened" on one side.
Tomorrow I will pull the float bowls and see if I neglected to punch out one of those little circles in the new float bowl gaskets.
thx
thx
