turk
I bought a new to me 1979 XS650 for my wife.
It looked good on Craigslist and in person,your basic 20 ft. semi-custom.
It came with a "build sheet from the PPO" that was tucked in with some paperwork that I got around to reading the next week.
The PO had mentioned having a build sheet over the phone,I really don't pay attention to those kind of things.
A bike is what it is.
I generally don't worry about claims of PO when buying a bike.
The first part of the Build sheet I dismissed as "11th grade automotive shop talk".
The second part which I could visually verify was accurate from what I know.
Dual front disc, Mikuni Vm carbs, extended swingarm,oil cooler,etc.
So yesterday I was following the excellent write-up on valve adj. form here and looked into the spark plug hole to see if I was at TDC.
I saw some "writing" on top of the left piston the was easily read.
80.95mm and S635
Are these 750cc pistons?
I did some research ,but, need some expert thoughts on this.
I was also able to verify the carbs are Mikuni VM38
The first paragraph of the build sheet went something like this:
it has a Bob Bertaut built 753cc engine with Web Cam #2and titanium valve kit and springs. Volkswagon valve adjusters and Mikuni round slide VM38 carbs, etc, etc, etc.
It is supposed to have been "Rodmans Special Roadster"
http://www.650motorcycles.com/rodman.html
My wife and are not "go fast" riders, really didn't need or want anything but a stock motor.
I do want a safe and reliable bike for my wife to ride.
I do need to know what I have so I can make it as good and reliable motor as I have the ability to.
Thanks for any advice or info you have!!.....Al
80.95mm and S635
