jims428
Besides bikes and cars one of my other interests is analog stereo equipment from the 60's & 70's, both vacuum tube and solid state.
One of the more common problems is dirty/corroded switches and contacts that make for poor, interment, or loss of connections.
Sounds familiar doesn't it?
The contact cleaner you get at the hardware store just does an OK job. You use a lot of it and it still does not do the best job.
Instead look for Caig's DeoxIT D5 (5% solution) http://store.caig.com/s.nl/it.A/id.1602/.f?sc=2&category=188
"Unique contact cleaner, rejuvenator, conductivity enhancer and lubricant; dissolves oxidation and corrosion on metal surfaces, fills in microscopic gaps and reseals surface for better contact to enhance flow of electricity. Improves connector performance/reliability. Temperature range: -34 to +200oC."
You can find it at Radio Shack, Electronic Stores, or online. It is a little more expensive than contact cleaner but a little bit goes a long way so you don't need to use much, and IT WORKS!
You just spray a little bit into your switches, hard to reach contacts, PWB's, etc, and let the chemical reaction do its thing.
For switches work the switches a bit. After a couple minutes spray a little more to flush out the crud.
I use a rag around the areas I spray as a precaution but for everything I've used it on it has not harmed any of the finishes. It dries in a couple minutes with no residue except maybe some of the crud it has flushed out.
Give it a try. It's one of those products that just works.
