I'm getting a lot of top end noise that seems to be getting louder. I know nothing about my engine other than it had nothing out of the ordinary in the oil or filters when I changed them. The advance shaft needed cleaning and relubing, and the cam chain required adjustment. I've been taking the bike out on short rides to check other things, like carb jetting and all the rest of a new build. The last couple of rides I noticed the sound of, what I thought was the cam chain whining as I rode. Last night it seemed to sound even louder. Other than loosening the oiling tube fitting and making a mess, is there any other way to check if the oil pump is sending oil up top? On a side note, when I first got this motor there was a bent oil pump shaft caused by someone evidently spinning the motor over with the tach drive loose and having it walk up and binding the gears. I changed out the entire cover with pump from a spare engine I had.
