TC, sorry if im stating the obvious, but the purporse of blipping the throttle, and double de-clutching, is to (as best you can) get both the input shaft (read crank shaft) and the output shaft (read countershaft, orfront sproket) spinning at identical speeds. This should deliver a perfect meshing of the gear selected. i often change gears in my toyota, up and down, without using the clutch, same method. cheers
Posted via Mobile
