I am doing a simple wiring harness similar to the one shown below. I have allotted room and mounting space for a 4 place fuse box ( which i already purchased and mounted), and was wondering if I could get away with only 4 fuses. Was thinking one 20amp for the main fuse between battery and regulator/ rectifier, a second ( 10 amp) fuse between kill switch and switched power from regulator/ rectifier, a third (10 amp ) fuse for headlights and taillights together, and a fourth (10 amp fuse) for the brake lights and turn signals together. Any thoughts on this? If it helps, the taillights and brake lights are LED and the turn signals are standard bulbs but very small bulbs and low current draw. Thanks
