Fernando
I pulled the motor to change the front cam chain guide, buttoned it back up and was cleaning the outside, pulled the oil pan and drain plugs to get all the plastic bits out and I found a ball bearing at the bottom stuck to the magnet! Where could this ball bearing have from from????!!!!! Is this a ball bearing from the clutch push rod? How can I check if it is? Its about 1/4 inch or 5/16th big. If it is can I just pull the rod out and push the ball bearing into the seal and push it down with the rod again? Trying to get a picture up soon
79 xs650
79 xs650
