Mark Tierney
I hope someone has had this issue before and can help save my sanity. I rebuilt my 1980 xs650 special SG and finally fired it up. Runs great but for some reason my rear brake light is always "On". I thought that I reversed a wire connector between the yellow and the blue at some point, but I went over every connection and can't isolate the issue. Most connections go through a connector and they all seem right. I replaced the ignition switch, front brake switch, rear brake switch, and headlight. I have unhooked the front and rear brake switches and still the same issue. Everything else works fine.
Any thoughts? Any help appreciated.
Mark
Mark
