DanielBlack
XS650 Junkie
I'll be back, have to respond at work.
Yes, but sort of.
As you've observed, the Blue wire supplies the Blue 'running lights' circuit.
When switched to ACC(Park), you saw that the Blue wire is supplied directly by the main ignition switch.
BUT, when switched to ON, the Blue wire isn't energized by the main switch. Instead, the main switch, via R/Y, sends power first to the 'lights' switch which in turn sends it down the line via a separate Blue.
Method #1 to turn on running lights: Ign switched to ACC/Park.
Method #2: Ign ON, 'lights/headlamp' switch ON
Why? Now's the time to look beyond the taillight and switches themselves. What else is powered via the Blue wire? Via the ACC position? Via the (main) ON position?
The meter lights are the little bulbs inside the tachometer and speedometer. The light up the instruments at night.
I may be wrong, but I think that MamaYama has different lighting arrangements in different markets. Don't Aussie bikes have a low powered light inside the headlight for "parking"?
I'm pretty sure that my ST1300 crowd has said that - and the Europeans have yet another setup with a "flash-to-pass" switch on their hi-low beam switch - which are not on either Canadian or US bikes.
It's important to use the correct wiring diagram for your bike and your market.
meter=gauge
Right, you're reading the chart correctly.
What else is powered when in ACC?
It is confusing when 1, (singular), circuit is referred to as Running lights, (plural), The Park light is a Park light circuit, (single). Running lights, (plural) are the Headlight and Tail light used together
Thats all that I can see. ACC just controls the meter lights and the parking lights. BTW should the YELLOW/ORANGE signal lights in the back come on as parking lights too and be steady like the RED parking "running" light when enabled??
No - the yellow lights are only for use as turn signal - just like on a car.
Ok, now, what is powered when ignition is switched to ON?
That Brown wire is a biggie. And from the engine stop switch...
You've got the skills now to further pour over this diagram. Keep putting the dots together. Ask questions to clarify parts you don't quite get.
BTW, Black wire? What's that?
