fyl1982
So, I replaced my rear tire and noticed... before I took the wheel off, the markers for the rear tire were off by about a full mark. I intended to correct this when putting on the new tire but I have a problem. The bar that holds the brake hub assembly is VERY close to my tire. Between tensioning the chain properly and aligning the rear tire to the markers, if I do that the tire will rub against this bar.
Here is a diagram I threw together in MS Paint...
So with the chain at proper tension I am about 5 and a half to 6 marks back on the chain side. On the brake side, about 4 and a half to 5 marks back before I get to within 1mm of the tire hitting that bar.
Is the chain too stretched out? Frame bent? Tire too wide?
This bike is in pretty good condition. Any help or advice would be appreciated. Thanks!!!
