girouxmcisaak
I've been working on a rebuild and I replaced both wheel bearings. The front went fine, but for some reason, the long spacer in the rear wheel won't stay put. I did make sure to put the top hat spacer into the bigger bearing, as well as the collar that goes onto the bigger spacer.
I used a bearing set to push the new bearings into the wheel, and I thought I had it all the way down. When I noticed it was loose, I used the bearing set again to push down on the oil seals but that probably doesn't do much in the way of moving the bearing. Did I get a bunk set of bearings (I got All Balls kit 25-1357)? Did I just actually not seat it all the way like I thought? Any ideas?
