Prisondawg
I'm trying to simplify my wires. My plan is to eliminate all the 10 amp fuses and keep only the 20 amp main fuse. There's a junction of red/white and brown wires. Are they technically the same thing ? I assume that the red/white wires draw power from the brown wire that is common power. The red/white wires feed the coil along with the TCI. My harness is a 78 however I modified it to work with my 81 engine with a single coil and TCI box. That being said would it make sense that I can just run any red/white wire into a brown and I won't lose mess anything up? I have my coil tapped in on one side , and the other side to the TCI. Should i just cut out any red/white wires that aren't going to a coil ?
