To be a type suitable for the 70-79 alternators, I'd expect an additional wire, which would connect to switched power (brown), to turn the thing 'on'.
Suppose we assume that:
3 yellow - 3 stator wires
1 red - battery(+)
1 black - battery(-) (ground)
Then, test those 5 lines just as you would if testing a rectifier.
If those 5 lines pass the rectifier test, then:
Connect red to battery(+)
Connect black to battery(-)
Measure voltage between battery(+) and green.
If any voltage shows, then it may be the 80-83 type.
Or, it could be a PMA rec/reg...
