xs650newb
Hello,
I am in the process of redoing my wiring harness on my '81 Special. To that end, I purchased the TC Bros chopper wiring harness.
O my regulator/rectifier I have an 8 pin connector. However, only 6 of the pins are wired. There is an additional red wire coming from the unit, which I believe at oe point was connected to the connector, but ripped out at some point. Is this correct? If it is that leaves 7 of the pins connected. How many should be connected?
Also, my ignition switch has 3 wires. Red, Blue, and Brown. If I turn the switch on it connects red and blue. Can I use this as my main switch for the bike and ignore brown. (I dont care about a 'park' feature.)
Thanks,
Adam
Thanks,
Adam
