Firstly, I'm a noob.
OK I have been try to remove the starter solenoid with no success. I ended up rounding out the top of the screw and can't get a socket to stay on the bolt. I've already removed the airboxes but still can't properly remove the solenoid. So now I am trying to remove the metal box/chassis which holds the solenoid, battery etc. Yes I know I'm probably making something simple so complicated but I'm frustrated after spending all day trying to get the solenoid out. I've already disconnected most of the wiring harness, removed the battery, and even removed the safety relay. The battery box can't be lifted through the top, though I would think it should. How do I get it out? Removing the rear fender or what?
Also, I bought in-line blade fuse connectors from Mikes. The wires are much thicker than those in the wiring harness for the fuses. Will a wire coupler be the best option for connecting the two?
Feel free to post links or ideas. FYI, I have a 1980 XS650 Special II.
Thanks in advance
Thanks in advance
