barelycompetent
81 XS650 Special
Once again I apologize if this has been asked and answered a thousand times, I have searched and searched but have not come up with what I am looking for. Could be my wording in the search I dunno. I have a 1981 special, all stock ignition and charging system. I have already converted the turn signals to LEDS with the flasher relay from superbrightleds. I am also running an LED brake/running light. My question is, I want to remove the idiot lights and the center gauge cluster and make my own little gauge with three simple LED idiot lights in it, yellow, red and green. Using the stock wiring can I just wire in the LEDS for each circuit or do I need a diode or resistor in the circuit somewhere? I know this has been covered before and again I am sorry for asking again, I just could not find it in my many searches. I know that when I changed the turn signals to leds, I had to pull the regular bulb out of the cluster to make them work, thereby losing my idiot light for the turn indicator, until I wire in a diode to make the regular bulb work again. I want to forgo all of that and just use leds as my idiot lights. Is it plug and play, or do I need something else in the circuit? Thanks for putting up with all my asked and answered questions again.
