larksnostril
Charlie
"81 Special: I removed right cover to fix kicker. Fixed it and did nothing else. Now the case will not go back on. The large gear of the tachometer mechanism (which has been working fine) appears to be impinging against the nut that holds the tachometer drive gear onto the shaft of the oil pump driven gear. I've slowly cranked the kickstarter to rotate the the engine hoping for meshing of gears as I press the case on firmly without effect. It's as if everything shifted potions once the case came off. The case came off without much effort so there must be some secret move I can't figure out. It's all covered up so no dust gets into the works, and after two hours of fiddling with it every which way I can contrive I'm wondering: What's my next move?
Charlie
Charlie
