fancyketchup
Condiment Enthusiast
Ok, Ive been having a problem with my 76' for a couple weeks now and Im starting to get real frustrated. It started running high idle from being lean after I cleaned out some crud that got into the carbs(have fuel filters now). Here is everything that I have done/replaced:
-Carb boots(from 650central) and clamps
-Repaired pinhole in left carb diaphram
-Installed carb kits
-Cleaned main/pilot jets
-Set float height to 25mm
-Ultrasonic cleaned carbs-sprayed passages with carb cleaner followed by air
-Checked valve clearances after setting chain tension
-Replaced throttle shaft seals
-Cleaned air filters
-Checked compression 120 left 115 right dry.
-Checked points gap
-Replaced plugs with new BP7ES gapped at .025
-Resprayed with carb clean while bike running and can not find any air leaks
-When I bought the bike it had been previously gone through by a shop and I found the needle raised to the highest position and it had 120 mains installed. Im assuming because they could not get 122.5's without ordering them. Ive got some on order but until then Ive got it set like this. The bike ran fine until this point like this.
After all this and the thing still doesnt run right, when I try to set the mixture screws using the dead cylinder method the bike stalls after a few seconds on both cylinders. Ive checked the sync with a motion pro guage and its good. The idle revs up on its own and it has no power. Im really getting irritated, anyone have any ideas?
-Checked points gap
