furrygreg
My son & I are finishing the wiring on his 1978 Yamaha XS650SE project bike. As part of the build up, we installed a new Boyer Brandson electronic ignition to do away with the old stuff, and a new PMA alternator kit to get rid of the old alternator. We got both kits from Mike's XS. I liked the idea of getting everything we needed in two complete kits, and the installs went well by following the kit installation instructions and viewing posts on this site. We have only run into one problem. What do we do with the yellow wire that runs from the safety relay that used to plug into the old alternator? From what I understand, it would use any voltage above 2.5 volts to open the circuit to the starter relay to keep the starter from being engaged while the eneing is running, and it also closes the relay to send power to the headlight. I saw this system in action before we tore down the bike, so I understand how it works. I like the idea of the bike automatically cutting out the starter while the engine is running as this is my son's first bike, and it will be one less thing for him to worry about. If we want to keep this system operational, where should I run the safety relay yellow wire to for a good power source? If we are not able to use the safety relay anymore, what is the correct way to rewire the harness to delete the safety relay. I suspect we are not the only folks that have been baffled about this subject. We appreciate any help we can get with this.
