XSRocket
Hi all!
I picked up my '82 XS650 about a month ago. It seemed to be running alright, but was a little tough to shift. I drained the oil to change it and check the shifter springs (one of them was indeed broken), only to find a LOT of metallic shavings on the plugs and sump filter, a bunch of aluminum and plastic in the other filter, and oil so dark I don't think the PO ever changed it...
Long story short I pulled the head off to replace the cam chain tensioner, and have been checking everything else out as I go. Things seem pretty ok, even the piston rings are all in spec, but I found this scratch in the right cylinder.
It seems pretty deep - I have a feeling this means a re-bore, but I was hoping some experts could confirm for me. How bad does it look?
