"Second Attempt " Another tracker
olddude13
tracker dude
Solon Ohio 44139
Just started a second tracker build here's what I have so far.
Complete bike gutted down to bar frame
Radian swing arm
R6 forks
R6 front rotor and caliper
Two Cast seven spoke Front wheels from 77 Kawasaki Kz 19'' x 2.15'' (may have rear made wider by Kosman )
Brembo rear caliper
Flat track wave rotor (rear)
Flat track type quick change sprocket
Just started to machine rear hub to sprocket adapter
Will post pictures soon
Radian swing arm
R6 forks
Brembo rear caliper
Looking forward to this. :)
A few pictures
Threading rear hub for sprocket bolts. Rotor side is all most finished will post pictures soon.
Working on rear caliper bracket and rotor carrier. Sorry for the upside down shots... just one of those days!
Roughed out the front rotor carrier , and blasted front wheel. Also mounted tire went with good years they are cd5's maxxis only come in cd3's now. Cleaned up top clamp milled off key boss and under side bored for bar clamps ....waiting for allballs stem bearings.
a few mores shots. Bar clamps are for mock up i will make better pair for finish. FYI if you buy a rear quick change rotor carrier and rotor from "chaney" the bolts he sends are way to small for rotor Too much play i ordered rotor front bolts for a 1991 gsxr 1100 they are shoulder type bolts.
Thanks pregrid, did you sell off your bike?
Nope not yet. Didn't expect to this time of year but there are a coupla fellas thinking about it. I'm in no hurry. Every few weeks (when the weather permits) I fire it up and take it for a ride. Puts a big smile on my face every time.
Here's what you can do with the left over nuts bolts and steel bits
Nice machine work! Like the build. The mini's are really cool,but where is the flat track mini.
