bdholsin
XS Enthusiast
On my '83 Heritage Special (stock electrical) I seem to be having a charging issue. I measured the voltage at my battery while the engine was running AND at about 3,000 RPM and it is only showing 12.25V in both situations. I've also pulled my brushes and measured them...they are showing 9mm and 10mm. Yeah, they are getting short but aren't down to the minimum 7mm to justify replacement (yet).
I've been using the "search" function and reading a pile of ways to diagnose what the problem is but I'm seriously confused as to what procedures will apply to my '83. I have TCI (not points) so I should be looking at procedures that are written for the later bikes, right?
I have my trusty multi-meter and can muddle through most diagnostic procedures. I just need to be pointed in the right direction. I'm not sure which of the following is could be:
1. Brushes (probably not as they measure "long enough" for the time being).
2. Stator
3. Rotor
4. Regulator or rectifier. This is where I was getting confused. Does my bike have either/both a regulator or rectifier?
5. Something else?
I'm electrically ignorant but infinitely enthusiastic. This is probably a dangerous combination.
Any help is appreciated.
Brock
2. Stator
3. Rotor
5. Something else?
Brock
