Right on thanks a lot. My bike will sit and idle perfect, but when I get about half way through my throttle in gear it is fumbling, like it isn’t getting enough gas, then once it works through it it feels like it hit a power band on a 2 stroke. Hoping some adgjustment will help that. Running straight pipes cut at the pegs with no baffle and cone filters.
search needle shim washer bs34 one washer works wonders on BS34 off idle stumbles.Right on thanks a lot. My bike will sit and idle perfect, but when I get about half way through my throttle in gear it is fumbling, like it isn’t getting enough gas, then once it works through it it feels like it hit a power band on a 2 stroke. Hoping some adgjustment will help that. Running straight pipes cut at the pegs with no baffle and cone filters.
Ha ha...yep, that and a little turn signal fluid and the bike should run perfect.This sure simplifies fuel system tuning--for any off-idle issues, swap out the main jets. I stand corrected on everything I thought I knew.
