Update:
This bike is running better than she ever has. I took her out for about an hour and a half today, with a couple of stops (shut off, let sit for a few moments, restart), and she ran beautifully, with the exception of one "spit" (didn't shut off, but recovered) when I was decelerating to pull into the driveway. I think that's deceleration-related. It's very rare, but it freaks me out a little because it's unexpected. But I don't want to mess with the float level for something so rare.
After about a 1/8th turn in on the air screw and fiddling with the idle speed screw a bit, the idle is such that I'm tempted to leave well enough alone. It will fluctuate a bit if the bike idles for a long time, but I try to avoid that, and at lights and such, it was fine... right around 1300 rpm or so.
Shifting was better today, with the Pennzoil 15w30 diesel. I think the trick with first gear is to drop down while the bike is rolling.
There were a few drops of oil in the drive today after returning home, but the bike was sitting slightly nose-up (usually she's parked flat), and I think it's residual from my chronic slight seep that's likely from between the case halves, left front. Meh. Seems to be controlled. *shrugs*
One thing... I almost lost my left side cover on the road! I happened to notice that it was loose... the bolt had backed out! It fits a little bit differently now, with the one carb setup. and I'm reluctant to really torque it down. I have a little rubber grommet on the bolts now, behind the covers, but I might try springs around the bolts to provide some compression so the bolts don't back out. Suggestions are welcome.
Incidentally, one of my stops was to the local bike shop to try to get a key cut. They couldn't do it, but the bike garnered a lot of attention and some good conversation. The one carb conversion was particularly interesting to one guy who worked there and was heavily into cafe bikes. He said, "Don't do anything else to her now... she's not overdone... classy." I was pretty proud of her today. It's been a long road. But today I felt as it it's all paying off.
Some fresh pics...
TC
TC
