TeeCat
One-Mik Wonder
griz...
You know, I wondered about some inertia- or momentum-related issue like this. It stands to reason. I'll have to try your test and see if I can reliably reproduce the behavior. When I initially thought the carb was flooding on my early attempts to fire the bike up, I checked the float height when I had it apart to install the new needle and needle jet, and it seemed at spec. However, if you look at some pics of my configuration from the side, you'll see an ever so slight downward list in the carb position; this position seems to be a function of the construction of the intake manifold itself. I wondered if that might be a bit of a factor, but I think Mikuni recommends a carb "posture" of within... I want to say about 20 degrees... of level. Saw that in my reading somewhere. But yeah... we're dealing in thousandths of an inch here, so it's tricky!
Well... time and weather permitting this weekend, I'll try your test(s). (My neighbors adore me, incidentally... Well... the kids do. Parents... maybe not so much. )
And you remind me... one thing I do want to address is ease of carb tweaks. In a stock configuration, I recall your saying how easy roadside tweaks are. I have noticed, however, that in my carb's location, it's really tricky getting that bowl off without pulling the carb off the manifold, which can get old fast. So I need to either investigate a 90-degree phillips, perhaps, or do John's phillips-to-allen mod like I did on my BS38s. Being able to just drop that bowl in situ would be a boon.
TC
TC, the low speed issue you're describing sounds a bit like what sometimes happens under braking if the float level is set slightly too low (fuel level too high); depression of the front end causes fuel to slosh forward, richening the mix.
TC
