Yep. Welded just on top. NOT moving though. Unless you heat it a lot which you could do if you had a torch I suppose. The bars it came with were bent, so it probably went down on those. I happened to have a spare set.
I used the welder to tack a bit of steel onto the one side and it actually came out remarkably good. Both sides stop solid now with clearance for the tank.
Yanked the front all the way apart. Triple is straight. One fork leg is what I would consider "Fine" one has a bit of a bend in it. Could probably use one fork leg or a pair if one presents itself cheaply.
I'm mocking it up now. This bike actually looks pretty awesome even in it's raw state. Carbs, Battery & battery box, wiring harness and it's complete.
My only problem is time. Kids are 4 and 6 and growing so fast it seems. I might end up shelving one of these projects for a while so i have more play time with them. Perhaps even try to make some room in the garage. We'll see.
