Rlauchard
So, after two years of rebuilding the engine, doing a full tear down, cuts, coatings, fights with the wife, etc.....I hit a huge milestone.
I rewired the bike completely and tied my last ground to the Pamco.
Unfortunately, all my wiring testing took the Ballistic battery I had down to 12 volts...which wasn't enough to turn the starter for more than a few seconds...hope that doesn't stay the case.
Anyhow...3 kicks and a full choke and bam....she's running...then died after a spark backfire from the left pipe.
Full choke and the push button starter fired it back up which makes me think the alternator wiring is good and charging the battery....then it died.
So...the problems I need to address and questions I pose to my helpful site brothers are:
1. I took my petcock off before painting...now that it's back on, it's leaking a bit from the face...like from under the silver face that has the engraving on it with on, res, etc...it was not leaking like that prior to removing it...any ideas?
2. I thought the petcock was a vacuum type deal...I thought I remembered having gas in the tank and having the hoses disconnected, but I also might remember having had the hose simply clamped off. It's the carb floats that stop the flow of fuel from the tank isn't it?
3. Is it possible that it's running goofy since it hasn't started in a year? I definitely ran it and adjusted valves,etc after the top end rebuild...thoughts?
I'm tired and mostly excited....thanks for all the help...what a ride it's been...now I just want to ride.
