1. Having trouble logging in? Try closing your browser and re-opening it. If that doesn't work, try a different browser or device. The site will be updated soon to resolve these browser issues.
    Dismiss Notice
  2. Dismiss Notice
So it begins.....
Discussion in 'The Garage' started by sweatybetty89, Aug 13, 2021.
  1. sweatybetty89
    sweatybetty89 XS650 Addict
  2. Jan_P
    Jan_P XS650 Guru Top Contributor
    1,038
    1,441
    163
    Sweden
    Aeehummm ... ..mmm
    Mr 5T says Yours is a 77 Model
    And the link you Posted says
    The E-Advancer Ignition System is a direct replacement for the Yamaha T.C.I. system on the 1980-83 Yamaha XS650.
    Usually it is not explicitly written a specific Year model range unless it is so
    There is mention of Bushings and a Rod.
    I can suspect without having read it that your 77 has internal Bushings in the cam Already ( for the advance unit )
    that a 80-83 does not
    What that leads to is uncertain .I do know that the bushings you have can come out . Done it myself.
    But this needs some investigation There is the Possibility the enclosed bushings in the kit for an 80 -83 don't fit a 77
    sweatybetty89 likes this.
  3. 5twins
    21,922
    15,470
    813
    Yes, according to the instructions you linked to, they do supply the needed part that replaces your mechanical advance unit and locks the advance rod to the cam. Yes, use your advance rod. You can ignore the parts about installing bushings in the ends of the cam, your cam already has them. That is needed to run this ignition on an '80-'84 model. The cams on those came with no bushings in them.
    thuban and sweatybetty89 like this.
  4. sweatybetty89
  5. grizld1
    grizld1 Grumpy old man Top Contributor
    No. The OE advance unit, points, points cam, and ignition rod must all be removed to install the Boyer system. The Boyer igniter box controls the spark advance electronically.
    Mailman and gggGary like this.
  6. gggGary
    gggGary On the road of life I'm a speed bump. XS650.com Supporter Top Contributor
    Mailman likes this.
  7. GLJ
    GLJ Never go faster than your guardian angle can fly. Top Contributor
  8. Raymond
    Raymond XS650 rider & fettler XS650.com Supporter Top Contributor
    If you buy the Boyer system, you remove the old points and the advance mechanism. Boyer supplies a long, threaded rod which fits along inside the camshaft and secured at the r/h end with a shaped spacer and a nut. The magnets for the signal attach to the points end of the rod. The static plate fits using the screw holes for the points. My XS has BB and I've had their systems on a Triumph TR6, Norton Commando and Kawasaki Z1 without no problems ever.
    Edit - crossed with Grizld, Gary and Greg
    Adamc, grizld1, Mailman and 1 other person like this.
  9. sweatybetty89
    Both blue box (Micro Power) and red box (Micro Digital) versions eliminate breaker points, condenser, and mechanical advance.The only difference is that the red box system requires a coil with 3.5 to 5 ohm resistance which the buyer must supply, and the blue box system requires a low resistance 0.6 ohm coil included in the Boyer kit. The same timing plate is used in both, and both advance the spark electronically in a continuous curve.
    I found this on a thread. looks like it does remove the advance. Then would this not be my cheapest option??? Plus mikes is out of stock on the ignition that replaces the breaker
    grizld1 and gggGary like this.
  10. GLJ
    Your best bet would be to get the Boyer. It's a complete kit, everything you need. If installed correctly once you set the timing it doesn't change. If it does change it's because of the cam chain stretching. The blue box is the best one they make. Whatever you do buy it as a complete kit.
    Adamc, grizld1, Mailman and 3 others like this.
  11. gggGary
    A much better track record is far more important than a few centavos.
    grizld1, Mailman and Raymond like this.
  12. sweatybetty89
    this bb system is not a great track record? the reviews i see are not bad. gary what do you know about them?
    gggGary likes this.
  13. GLJ
    The Boyer system has a excellent record. I have it on my bike, have had no problems. I use the blue box.
    I think Gary meant don't go on price alone. Mikes kit may be cheaper but it's track record is iffy.
    grizld1, Mailman and gggGary like this.
  14. sweatybetty89
    mikes kit is actually more at the end of the day. bb is the way i am going to go. it just seems simple. we like simple
    Mailman, gggGary, GLJ and 1 other person like this.
  15. The newer digital Boyer setups also have an idle stabilization built in, they adjust the spark advance as needed at low rpm to keep things steady.
  16. sweatybetty89
    Here is my orientation from crank to cam. Looks about a link off
  17. gggGary
    Dunno, that looks OK?
    But since you are this far a new front guide is prolly in your future.
  18. sweatybetty89
    I went in to the guid and it looks to be in okay shape. The side of the guide looked like maybe it could of been worn. And is that not just cocked a little to the left? It should be at 12 o clock position correct?
  19. sweatybetty89
    Have jug off and cylinders off now didn't snap pics of the guide or pistons last night forgot. Over all it looked pretty good in the cylinders no scarring
    gggGary likes this.
  20. Raymond
    It looks a little to the left, but that could be a worn cam-chain.
    Adamc, Mailman and grizld1 like this.
Share This Page
