Equalizer
I have a Sporty tank that has male thread on the right side. I bought a 22mm petcock thinking that was the right size, but it only goes on about two threads and thats it.
I need help
I need help
I have a Sporty tank ...22mm petcock
Old iron head tanks and most aftermarket tanks are 3/8" NPT, but the modern OEM Harley tanks use this petcock:Shun't the petcock be 3/8 NPT?
Half the fasteners on any Harley made in the last 15 years are metric.
It is possible that you have a bad thread on either the bung or the locknut, so examine them carefully. They are very fine threads, and it doesn't take much to bugger one. Other than that, if what I said before makes sense, then make sure that you don't have the big locking nut upside down, and that you are trying to screw the reverse threaded part of the locknut onto the bung. When everything is right, the locknut should screw at least a good half inch onto the bung, nut just two turns like you wrote.This has been a PITA.
