Howdy, I've got a 1981 special ii, and I'm doing a bit of work on it. I got the starter block off kit from mikesxs as i didn't want to mess with rebuilding the starter and just go without. I was wondering if I could alleviate the two small idler gears in the area where you take off the starter that it would normally engage. With the block off spacer, it does not allow the gears to mesh with the gear protruding from the lower gearbox area, it pushes it out about a quarter of an inch or so, just enough so they no longer are able to engage, which shouldn't be a problem since there wouldn't be a starter to engage them anyhow correct?
