BBQRider
Thanks guys for all the help. Between your advice, other posts and the manual, I'm getting there. So the things I've done are: connected the clutch wire, connected the side stand wire and did away with the relay off the side stand wiring (those wires I simply tied off and wrapped well for now). Seems to run fine but I wanted to make sure this was not an issue of any kind? Where I am now is: 1)The head light does not come on and 2) neutral light always stays on. I'll worry about the neutral light later but for now the headlight. I found a thread started on May 15, 2016 entitled "safety relay gone bad?" It seems to coincide with my issue so i did what it said and tested the relay by jumping it. Relay seems to be fine. Next I checked the battery output because in the thread it says that the alternator needs to be pushing enough voltage (about 4.5) to make the relay trip? So my (recently charged) battery output is 11.9-12v when off and once started does not go up but actually goes down a bit even at 3000 rpms. So, it sounds like I have an alternator issue?? Ive tested (with my limited knowledge of an engine and ohm meter) the resistance and it seems to be around 3? First actual question is: does it sound like I'm on the right track? Second question, Do I start a new thread (relating to alternator)? Ive seen that recommended when someone has two many things going on at one time. Thanks again for all the help. I feel like I'm getting there and learning quite a bit as I go!
