BBQRider
So I've got my bike back together (83 xs650) and she's running great. The only problem is I have to kick start her. The start button is not working for some reason. I've been searching threads and trying different things. Just fyi, she started fine prior to disassembly. I've jumped the starter solenoid like I saw on one post and the starter seem s to work fine. I did remove the cable at the clutch (sensor)and thought I had read that you do not need to do anything other than unplug it inside the headlight cover. Is this true? I'm getting power at the ignition fuse. I've looked for broken or disconnected wires but haven't found any. Just not sure what direction to go next? Help??
