BBQRider
Thanks for the guidance Retiredgentleman. I have been shying away from it being the rec/reg unit from the beginning of this process because when I bought the bike, the PO told me it was having a charging issue. He kept it on a battery tender. He told me in his searching he thought it was the rec/reg unit but was not sure. He had purchased a "new" one that he said he had just not had the time to put on. As soon as I had a chance I installed the new one. However the problem still exists. When I first got the "new" one out of the box it looked a little suspect. It looks like a new one except for the fact that it had bolt markings on it where it looked like it had been mounted? I also thought it was a little suspicious that he had not made the swap because its a pretty easy thing to do. Then the other day I ran it through the rectifier test in the Haynes manual and it checked out fine. However this is a test for the rectifier. I can't find a specific test for the regulator or have I already unknowningly done this? So my question(s) is there a good chance that "new" rec/reg could have been returned defective? or could something be going on with my bike to make it defective? (this would be good to know before installing a new one-only to ruin it) Lastly, I've seen where some people use an automotive regulator as a replacement? Do you do that while using the original rec unit or do you have to replace both (the reg AND the rec)?
