jmason
Need help!,
I installed both e advancer and pamco ignition. Here is the issue? No spark.
1. checked battery with load meter and is good.
2. Meter on battery reads 13.45
3. Unit is switched and fused. Both continuity meter fine
4. Voltage between red and green connection between sensor and e advance read 13.45 volts
5. Voltage at coil between red and green wires, zero
6. Voltage from red to ground at coil 13 volts
7. Voltage from green to ground at coil 13 volts
Fuel reaches cylinders
Thoughts?
Jim
Thoughts?
Jim
