and as I said before the cam timing is directly on point sccording to the mega cycle time card and I still had to modify my ignition timing plate to fire... So that statement in this case isn't all that accurate...I had to cut notches way more into the timing plate, and advance it so far that the second screw hole can't be screwed into because the board on the timing plate is blocking it... Which is not feasible to permanently run like that...I only did it to see how far I needed to advance the timing plate in order to run
