Try turning the mixture screws out four turns, FIRST as is...
This is a complex issues so here is a simple answer that my help not confuse the issue,,,Your pilot jet and pilot air is the curcuit that the bike starts on.....You adjust the air fuel mixture with the mixture screws one on each carb.... your main jet is for full throttle and your needle jet is for midrange running.. these so called circuits overlap....
If you want to run the bike on idle you need to put your filters on and play with the pilot circuit and mixture screws if the bike back fires its not enough air, turn the miture screws out.
MULITIPLE JET CHANGES WILL NOT HELP... ONE CIRCUIT AT A TIME >>>>MAIN JET AND NEEDLE ADJUSTMENTS WILL NOT IMPROVE STARTING ISSUES...CONCENTRATE ON PILOT JET >>>PILOT AIR JET AND MIXTURE SCREWS for fuel starting issues...
Jetting is a long process and should be done a circuit at a time... then you can see if what you have changed had a good effect or poor effect.
Questions Are
are the carbs clean and balanced, valve lash correct, timing correct ,tensioner correct ,spark plugs good with correct gap...
breather from tank connected.
breather holes on tank cap clear
pet cock not on prime this will flood the carbs and is an easy error. reserve or "ON" is what you need
Recap
First Circuit ...Pilot air Pilot jet and mixture screws are your Idle circuit (for starting the bike and upto quater throttle)
Second Circuit .....Needle jet then comes onto play overlapping with the first circuit and last circuit... Known as mid rage to 1/4 to 3/4 throttle..
Third Circuit .....Main jet when you have the throttle fully open giving it the BEANS....BOOOOOM...
This is the best and easyest way to think about it...Carb theory is more complex than this ,,,but remebering the above will help get you in good area, in terms of getting the bike running.
once the bikes running,, then beleive it or not,, you start with the main jet ,then you work your way back through the other jets.. your eyes inside the engine are the spark plugs they will tell you if you are running rich (too Much fuel) or lean (too little fuel )...
Dont forget set the carbs up on the bike with the air filters on and the mufflers you are going to use fitted . adding thes components later will change everything...
best of luck FUNKY
