ABill
I replaced the handlebars. Electronic starter works fine, everything is turning over as it should, but just just no ignition.the red wire that goes to pamco, e-advance and coil needs to be +12 there may be a separate fuse on that wire. Pamco recommends installing a 7 amp fuse for ONLY that circuit. OK you said handlebars do tell; what did you do at handlebars??? The ignition power wire runs through the RH switch. Clues Watson! I can smell the clues floating on the gentle summer breeze.!
