Agreed. I am not an electrical expert but I have spent my entire career using electrical and electronic equipment and the number of actual electrical component failures (aside from burnt out bulbs of course) that I have experienced could be measured on the fingers of one hand (well, maybe two - but it's been nearly 40 years). It simply doesn't happen that often.
Most electrical issues with a given component are either connector problems (loose, corroded etc.), or they're caused by a failure of ANOTHER component, or they are what are sometimes known as dumb thumb issues. (In Schlumberger Wireline, these were called Group 7 Non-Hardware or Software Failures). I can still hear my instructor at the training centre in Port Harcourt Nigeria yelling at me: "Pierre: do not make zee Group 7 f@ck-up or zee client - he will 'nut be 'appy!!! " (imagine that bellowed with a thick French accent in a very loud voice).
So....while I have no doubt that these rectifiers are dying - I think that the cause simply must be elsewhere as suggested by DoubleE and others. Accordingly, it seems a bit pointless to simply install another rectifier until the root cause has been identified, isolated and defeated.
My suspicion is that another charging system component is going south....or that it is related to the very cool and highly worthwhile LED lighting upgrades that Daniel has done - I very much doubt that it is simply vibration. These bikes all vibrate - and yet most of them operate quite reliably without continually destroying solid state components. Besides, I watched Daniel start Stella up and she is one of the sweetest running 650s I've ever seen.
Anyhow, that's my 1.57 cents (USD) - aside from saying to Daniel - you will get this fixed my friend, and when you do, it will likely turn out to be some simple dumb@ss thing but you will have learned a lot in the process.
Pete
PS - one way to test this would be to disconnect ALL lights and go for a ride - obviously with another rider alongside as a guard. No flames please - I recognise that this is an unorthodox and potentially risky course of action, but you need to isolate this to either the charging system- or - the lighting.
