Wow, busy forum recently.
We need those dowsers from the “Water Witch” thread to step up there game and start dowsing for electrical gremlins.
Uh-oh.
Well, here's the take from someone who uses a smoke detector as a cooking timer.
As far as load-dump and such, it's not so much as the output from the stator windings, but the interrupted current flow in the rotor. Modern regulators, and those semiconductor regulators used on 80-83 bikes shouldn't have this problem.
http://www.xs650.com/threads/alternator-rotor-inductive-kickback.42605/
...Max charge slowly dropped from 14.2v at the start down to 13.9v ...
... drift, or systematic drift from say 14.2v down to 13.9V??
My 2 thoughts on this.
1- If the voltage sense of the regulator and the voltage tap point for the voltmeter are at different locations, this voltage variance could just be caused by resistive current between those two points.
2- If one diode breaks down, generator output is reduced, regulator increases demand, and the remaining 2 diodes would need to carry more current, increasing heat on them, leading to cascade failure.
...if there is a break in the windings when heated, then as the windings cool (from no current) they establish continuity again and the amps spike because the bike is turning 3-5K rpms?
There *might* be a break, frame short, or crossover, in the windings, creating intermittant voltage/current surges in their outputs. I think there's a total of 24 field posts in the stator, and for a 3-phase that would be 8 posts per phase. I have no idea if those posts are wound in series, parallel, or a combination. But, an intermittant break, or short to frame ground, or crossover to another winding, could cause strange output spikes.
But, by the book, the stated rating of the better import rectifiers is well above what the XS650 stator can throw at them. But, some of those rectifiers are available in as low as 50 volt ratings, and lower currents, which would be risky. Wonder if any of those got relabeled and slipped into the supply stream.
... I have spent my entire career using electrical and electronic equipment and the number of actual electrical component failures (aside from burnt out bulbs of course) that I have experienced could be measured on the fingers of one hand (well, maybe two - but it's been nearly 40 years). It simply doesn't happen that often...
Pete, in your professional environment, with industrial and automotive grade electronics, I would agree. But in the electronics hobbyist arena, flooded with consumer grade components, low quality stuff is somewhat expected. Many of us buy items in bulk, then hand select what works, or within margins, toss the junk.
...Two Windy Nation rectifiers are on their way, as linked to by 5twins.
Given the situation, a prudent move.
If you like, you could send me the failed rectifiers, and I could crack into them and try to do post-mortems. Which includes dowsing rod whippings. PM if you want to pursue this...
