DanielBlack
XS650 Junkie
Thank you gentlemen, it's been a good day covered in grease. Plenty of it, as you've seen on the bike. What you didn't see was the brunch of biscuits and sausage gravy my wife plated up. Grease inside and out.
All-dressed chips, I'm intrigued. And just because you've asked so nicely, here's a video to start the conversation.
Dash lights and run lights with ignition switch.
Turn signal switch operates the respective side's relay and switches it to a flashed power source.
Old 'Lights' switch operates the 4-way hazards. Switching both sides to the flashed source.
Headlight is switched off while in neutral. Hi/Lo is still operated by stock switch.
Brake light has a modulator, but the video segment doesn't show it too well. At least on my phone's screen.
The fuses are main (R), switched (Br), lights (L), ignition (R/W). The relays under the seat are switched (Br) and ignition (R/W). In the old regulator spot under the L side cover are L & R Turn (Ch & Dg, respectively), Hazards (L/B), and headlight (Sb).
Still to do, wire in the headlight's pilot light so the reflector is filled when the headlight is off. Possibly add in the dash charging idiot light off the safety relay.
